Composite functions and domains
bacon
The forward-back function is
f (t) = 2t for 0\leq{t}\leq{3} ,
f(t)= 12-2t for 3\leq{t}\leq{6}. Graph f(f(t)) and find
its four-part formula. First try t = 1.5 and 3.
There are four possible composite functions from the two given functions:
2(2(t))=4t
12-2(2(t))=-4t+12
2(12-2t)=-4t+24
12-2(12-2t)=4t-12
Since the domain of f (t) = 2t is from 0 to 3 and the domain of f(t)= 12-2t is from 3 to 6 it seems to me that only the first and fourth functions are valid. Functions two and three have a part of the composite function applied outside its defined domain. Instead of a four part formula I get a two part one:
2(2(t)) for 0\leq{t}\leq{3}
12-2(12-2t) for 3\leq{t}\leq{6}
The answer in the back of the book gives:
2(2t) for 0\leq{t}\leq{1.5}
12-4t for 1.5\leq{t}\leq{3}
12-2(12-2t) for 3\leq{t}\leq{4.5}
2(12-2t) for 4.5\leq{t}\leq{6}
I also don't see the relevance of "First try t = 1.5 and 3".
Any help will be appreciated.
The relevance is just so that you see whether inside its domain it's a continuous function. though maybe with sharp corners (if the slope of the function is not an everywhere continuous function). You have a formula f(t) = one thing for a stretch up to t=3 but another thing for t\leq{3}. Can you see intuitively that if the two formulae give the same result for t=3 the function is continuous, and if not there is a discontinuity?
And what is the relevance of that? Well in dealing with a function you'll almost always want to know what it looks like - you would be naturally led a the start to look at f(x) at the break point t=3. As for 1.5 - well you'll see when you have calculated f(f(t)).
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
