What is the average mechanical power output of the engine?
The discussion focuses on calculating the average mechanical power output of a car engine and the volume of gasoline consumed during acceleration. The car accelerates from 0 to 40 m/s in 10 seconds, and with an engine efficiency of 22%, the average mechanical power output is determined to be approximately 107 horsepower. The total thermal energy required is calculated using the relationship between mechanical and thermal energy, leading to a gasoline consumption of about 0.079 liters. Participants clarify the conversion between mechanical and thermal energy, emphasizing the importance of efficiency in these calculations.
huybinhs
A car with mass 1000 kg accelerates from 0 m/s to 40 m/s in 10.0 s. Ignoring air resistance. The engine has a 22% efficiency, which means that 22% of the thermal energy released by the burning gasoline is converted into mechanical energy.
a) What is the average mechanical power output of the engine?
b) What volume of gasoline is consumed? Assume the burning of 1 L of gasoline releases 46 MJ of thermal energy.
\Deltax = [(v + v0) * t] / 2
Poweravg = work/time = energy transformed / time
Efficiency = Wout/Ein = Pout/Pin
a) \Deltax = [(v + v0) * t] / 2
=> \Deltax = 200 m
Work = m g x = 1000*9.81*200 = 1962 kW.
Wout = 0.22 * 1962kW = 431.64 kW.
1hp = 746 W => 431.64 kW = 579 hp = WRONG answer
b) I have no ideas to start. What is MJ?
Please advise! Thanks!
=> \Deltax = 200 m
mgx is the work done done on an object by the gravitational force as it falls a vertical distance x. The gravitational force is irrelevant in this problem; the force is supplied by the engine. Also, work has units of energy (Joules) not power (Watts).
A way to find the average power is, indeed, to find the work done by the engine: Work=Fx. You already found x, assuming the accerelation is constant. Since you're looking for average power, that's ok. Then you need to know the average force, which you can find from the average acceleration.
An easier way to do it is to look at the initial and final energy (kinetic only in this case). Then you know the total mechanical energy suppilied in those 10 s, from which you can get the rest.
In (a) you calculated the mechanical energy. The thermal energy is much larger, since the mechanical energy is 22% of this. So you shouldn't take 22% of the answer in a).
MJ is a megajoule: 10^6 J.
a) Ok. So total mechanical energy suppilied in those 10 s is
W = Kfinal - Kinitial = 1/2 mv2 - 1/2 m(v(0))2 = 1/2*1000*40^2 = 8*105 J.
Then the average mechanical power output of the engine is:
Power average = 8*105 / 10 = 8*10^4 W = 107 hp final answer for (a).
b) The engine has a 22% efficiency, which means that 22% of the thermal energy released by the burning gasoline is converted into mechanical energy.
Thermal Energy = 8*10^5 - (8*10^5 * 0.22) = 624000 J
Assume the burning of 1 L of gasoline releases 46 MJ of thermal energy, so:
624000/(46*10^6) = 0.014 L = answer.
Are both of mine answer and calculation correct? Please advise! Thanks!
Updated: I got the (a) is correct, but (b). Please advise!
Your first answer looks right. Your second answer looks wrong, at least to me.
I'm just not sure if you converted mechanical energy to thermal energy, considering that thermal energy should be over three times as big as mechanical energy, and yours is lower.
Edit: Yeah...
Think about this equation that I pulled from the words of the question:
E_m=.22E_t
Where E_m is mechanical energy and E_t is thermal energy.
I'm really confused on (b). So
The engine has a 22% efficiency, which means that 22% of the thermal energy released by the burning gasoline is converted into mechanical energy means:
Thermal Energy = 8*10^5 + (8*10^5 * 0.22) = 976000 J
976000/(46*10^6) = 0.21 L = answer.
How is it?
Edit: Yeah...
E_m=.22E_t
=> Et = 8*10^5 / 0.22 = 3636363.636 J
3636363.636 / (46*10^6) = 0.079 L.
Is this correct?
Finally I got (b) correct. Thanks all ;)
