Describe the motion of free fall from different observators
The discussion centers on analyzing the motion of a light bulb falling from the ceiling of a horizontally accelerating train. Observers on the rails perceive the bulb's motion as parabolic due to the influence of gravity, while those on the train experience a fictitious force acting backward, resulting in a different trajectory. The equations of motion indicate that the bulb's path is influenced by both the train's acceleration and gravity, leading to complex motion descriptions. The participants express uncertainty about the application of Galilean transformations and the correctness of their equations. Ultimately, the conversation highlights the differences in perceived motion based on the observer's frame of reference.
fluidistic
Describe the motion of a light bulb falling from the ceiling of a train with a constant acceleration. The train's motion is horizontal with respect to the ground.
Describe the motion of the light bulb if you are at rest on the rails. If you are at rest on the train. If you're experiencing a free fall motion with respect to the rails.
None given.
My intuition: On the rails, I'd see a parabolic motion. On the train I wouldn't see a vertical straight line, I'm not 100% sure about what I'd see. On a free fall motion with respect to the rails, I'd see a horizontal straight line.
I don't know how to set up the equations of motion in the different frames of reference.
I'm tempted to say that for the guy on the rails, \vec a (t)=a \hat i - g \hat j but I wouldn't answer this. When the light bulb is cut from the ceiling, there's nothing that could apply a force and hence an acceleration on the bulb, except gravity. Hence I'd answer \vec a (t)=- g \hat j.
So \vec v(t)=v_0 \hat i -gt \hat j.
Thus \vec r(t)=v_0 t \hat i +\left (H-\frac{gt^2}{2} \right) \hat j where v_0 is the velocity of the train when the light bulb is cut. Thus, it is the same motion (parabola) as if the train was moving with a constant velocity v_0 and no acceleration; according to this observer.
With the frame of reference falling with respect to the previous one, \vec a (t)=0 \hat j. Thus I can directly write \vec r(t)=(v_0 t+d) \hat i, a horizontal straight line.
Now... on the train:
\vec a(t)=a \hat i - g \hat j.
Hence \vec v(t)=a t \hat i - gt \hat j.
Therefore \vec r(t)=\frac{at^2}{2} \hat i + \left (H- \frac{gt^2}{2} \right ) \hat j which seems to me a straight line (not horizontal though), but I'm not 100% sure. I've taken vector calculus so I MUST be able to answer this with ease, but I should re read my course I guess. Unless you help me recover from this memory-loss.
Are my results good? I didn't use any Galilean transformation, I guess I should have? I only used an intuition, very un-rigorous. Is there a rigorous way to solve this problem? Like for example describing the 3 reference frames from only 1 and then use a Galilean transformation to describe everything they ask for...
No, that's not right. On the rails, you're in an inertial frame, and the only force on the object is gravity. In the train's frame, a fictitious force ma seems to be pushing the object backwards as gravity pulls it down.
). I reached \vec r(t)=v_0 t \hat i +\left (H-\frac{gt^2}{2} \right) \hat j.
From this I now reach y(x)=H-\frac{gx^2}{v_0^2}.
This was by assuming \vec a (t)=- g \hat j.
Yes I know... that's why I wrote \vec a(t)=a \hat i - g \hat j. Is this all wrong? If so, I don't see where in the equations.
By the way I just remember how to find the motion of \vec r(t)=\frac{at^2}{2} \hat i + \left (H- \frac{gt^2}{2} \right ) \hat j, which is indeed a straight line.
Now, have I used the good equations?
