Can a 1.3 hp Engine Power Our Prototype Car?
A 1.3 hp engine may be suitable for the prototype car, which weighs 120 kg and reaches a maximum speed of 13.88 m/s, given that calculated net power losses amount to 1.234 hp. Key considerations include rolling resistance, road gradient, and drag, with specific formulas provided for each loss. Additional factors such as drivetrain friction, safety margins, and acceleration needs were raised as potential oversights in the initial calculations. To determine the power losses through transmission, overall efficiency should be calculated based on the number of gear sets and their respective efficiencies. Ultimately, the engine must operate under optimal conditions to ensure adequate power delivery to the wheels.
Carvinos
Hello!
Actually i want to find the required power of an a single cylinder air cooled 4 stroke OHV engine. i have calculated three power losses, power loss against road gradient (Pg), rolling resistance (Pr) and drag (Pd) using the following formulae:
Pg=M*g*v*grad=1.095 hp
M(mass of the prototype car)=120kg, g=9.8 m/s^2, v(prototype car velocity)=13.88 m/s, road gradient= 5% (0.05)
Pr=RRC*M*g*v=0.109 hp
RRC (rolling resistance coefficient)=0.005 for a bicycle tire we are using in our prototype car
Pd=0.5*rho*v^3*Cd*A = 0.030 hp
rho=1.099 kg/m^3, Cd (Coefficient of drag)=0.04 in case of our prototype car, A=0.384 m^2
Net power losses=Pg+Pr+Pd=1.234 hp.
Now please tell me can i use an engine of 1.3 hp of 35cc volumetric capacity in our prototype three wheeled car. Generator is the only accessory that will be connected with the engine to charge the battery.13.88 m/s will be the max. speed of our prototype car, 120 kg is the mass of the prototype with driver. reply soon please
Did you calculate the rolling resistance for all wheels?
Have you applied a safety factor, and an allowance for acceleration (and not just travel at a constant speed)?
Have you considered friction in your drivetrain?
Have you considered conversion losses through the powertrain (including your 'generator'?)
Is your engine going to be operating at optimum conditions for 1.3hp?
ok.thnx.tell me please the procedure of how to calculate the power losses of engine through transmission.
For every gear set or belt drive set, assume 95% efficiency. For every chain drive set, assume 92% efficiency. Multiply all of them for overall efficiency.
Ex.:
if the power of your engine goes through 3 gear sets before reaching the wheels, your overall efficiency would be 0.95*0.95*0.95 = 0.857. So if you need 1.234 hp at the wheel, you need 1.234 / 0.857 = 1.44 hp at the engine.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
