Center of momentum for particle collision
The discussion revolves around solving a particle collision problem involving a stationary particle of mass M and a moving particle of mass m with speed v0. In Part A, the user successfully derived the velocities of both particles in terms of the center of momentum speed, vcm. However, in Part B, they struggled to express vcm using the condition that total momentum in the center-of-momentum frame is zero, leading to confusion about the application of the Lorentz factor, gamma. The user ultimately found a solution for vcm but questioned why the gamma factor was based solely on v0 rather than v0 - vcm. The conversation highlights the complexities of applying relativistic principles in particle collision scenarios.
quietrain
Consider a collision in which a stationary particle with mass M is bombarded by a particle with mass m, speed v0, and total energy (including rest energy) Em.
PART A: Use the Lorentz transformation to write the velocities vm and vM of particles m and M in terms of the speed vcm of the center of momentum.
PART B: Use the fact that the total momentum in the center-of-momentum frame is zero to obtain an expression for vcm in terms of m, M, and v0.
ok i found the part A after like a gazillion of tries
but the problem is part B. i have totally no idea... i tried to use mvm=mvM since the total momentum is 0, but i don't get the ans. almost all my answers are monstrous looking expressions
help greatly appreciated!
PS: part C was adding part A and B together to get the available energy for particle collision which i got the answer from my textbook but my textbook doesn't show how to derive it. would be great if someone could tell me how to combine part A and B to show this part C thanks
wow... i found the answer after crazy amounts of trial and errors... but i still don't understand why
my solution was, since total momentum = 0 in the center of momentum frame, then the initial momentum = 0 from conservation of momentum.
so my equation was (gamma)(m)(v0-vcm) - (Mvcm) = 0
so making vcmthe subject, i find that it is = mv0 / {(M/gamma) + m}
but the problem is the answer's gamma is just using 1/ sqrt(1 - (v0/c)2), but shouldn't the gamma, which is the factor in special relativity, be using v0-vcm instead of just v0?
