Find Initial Angle to Hit Target 100m Away with Rifle at 30deg Angle
  • Thread starter Thread starter Crebble32
    Motion
To determine the initial angle needed for a rifle to hit a target 100 meters away at a 30-degree elevation, the shooter must analyze projectile motion using specific kinematic equations. The bullet's velocity is 300 m/s, and the target's height is calculated to be 57.75 meters. The discussion highlights the importance of breaking down the motion into horizontal and vertical components, adjusting for the angle of inclination. The time of flight and horizontal displacement formulas are crucial in solving for the required angle of projection. Ultimately, the user expresses gratitude for the guidance received, indicating a breakthrough in understanding the problem.
Crebble32
A rifle fires a bullet at 300 m/s at a target that is up on a wall 100 m away. The rifle's line of sight creates a 30 degree angle with the horizon. What initial angle does the rifle need to be directed to hit the target?
The formulas I thought I needed are:
Vy=ViSIN(30) Here my Vi is the V-"not"
Vx=ViCOS(30)
I found that the height of the target is 57.75 m, and the hypotenuse is 115.5 m...
I was told to find time then use a kinematic equation. So I found t=.33. I came up with several different angles in several dfferent ways and they are all too large... My prof said that it is only raised a very little bit. I have had MANY failed attempts at this and just can't figure it out.
I appreciate any help possible!
Whenever solving problem for inclined plane, consider axis along the inclined plane as x-axis and perpendicular to it as y-axis. Then
Vi(x) = Vi*cos(θ-α)
a(x) = -gsin(α)
Vi(y) = Vi*sin(θ-α)
a(y) = -gcos(α) where α is the angle of inclination and θ is the angle of projection along the horizontal.
Now proceed as usual in the projectile motion.
I am just working in circles... just come up with the values I'm already given. I don't understand what formulas to use...
Time of flight T = 2vsin(θ-α)/gcosα
Horizontal displacement OX = vcosθ *T
Range along the inclined plane = R' = OX/cosα.
Angle of inclination α is given. Now find θ.
Thank you so much for your help! I think I finally got it :)
