Design a Telescope Optics for Spy Satellite- Angular Resolution & Mirror Size
  • Thread starter Thread starter BurnieMac
    Optics Telescope
To design a telescope for a spy satellite at 500 km altitude, an angular resolution of approximately 5.0x10^-8 degrees is required to clearly see objects as small as 1 inch. Using Rayleigh's criterion, the primary mirror must have a diameter of about 12.2 meters to achieve this resolution with a wavelength of 500 nm. The feasibility of constructing and launching such a large telescope is questioned, as it would need to be five times larger than the Hubble Space Telescope and significantly more complex to launch. The discussion highlights the challenges of both the engineering and logistical aspects of creating a satellite telescope of this size. Overall, the design poses significant practical challenges despite the theoretical calculations.
BurnieMac
This is a question on my final review.
Imagine you are given the task of designing the telescope in a spy satellite that is
going to be launched into an orbit 500 km above the surface of the Earth. The agency you
are working for wants to be able to clearly see objects as small as 1 inch = 2.5 cm (for
example the headlines on a newspaper).
a.) Calculate the angular resolution needed to achieve this.
b.) Given that diffraction is the ultimate limitation of your telescope, how big will the
primary mirror need to be? Use 500 nm for the wavelength of the light.
c) In one or two sentences, comment on the feasibility of your design. Hint: for
comparison the largest Earth based telescope has a 10 meter diameter mirror, the Hubble
space telescope has a 2.4 meter diameter mirror.
I am really lost.. My knowledge is very poor for this chapter, I read the chapter earlier and still don't know.
Much help from your bright minds would be appreciated!
Not sure
a. )
Theta = Object height / Object Distance
In that case it is 5.0x10^-8 degrees
b.) How big will the mirror have to be..
I used rayleigh's criterion.
Theta(min) = 1.22(wavelength) / D
Solved for D, giving 12.2m
c.) No idea
BurnieMac said:
a. )
c.) No idea
(a) Okay, but that should be in radians.
(b) Looks good.
(c) Mainly a common-sense question. How feasible is it to launch a telescope 5x larger (and 25x times the area) of Hubble? Or to not only build something larger than any telescope that has ever been built, ever, but launch it into orbit as well?
