Designing the Perfect Egg Drop Project for Physics Class
The egg drop project requires a design that effectively protects an egg from a 3-meter fall using limited materials: 20 drinking straws, 30 cm of tape, and one 8x11 piece of paper. Successful designs often focus on creating a cushioned structure that absorbs impact and distributes force. Utilizing straws for a lightweight frame and the paper for additional padding or a parachute effect can enhance the egg's chances of survival. Experimentation with different configurations and testing prototypes is encouraged to optimize the design. Collaboration and brainstorming with peers can also lead to innovative solutions.
Midas.
So we have an egg drop project due at the end of the semester for my introductory physics class. We're dropping it from the second story, which is about 3 meters down I believe. The materials we are given are 20 drinking straws, 30 cm of tape, and 1 8x11 piece of paper that we can cut/fold and do whatever we want with.
So my question is what design would be best for the success of thiis project? All help appreciated, thanks.
Anyone?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
