Is the Null Space the Same for (T-λI)^k and (λI-T)^k in Linear Algebra?
tinynerdi
Let T:V->W be a linear transformation. Prove that if V=W (So that T is linear operator on V) and λ is an eigenvalue on T, then for any positive integer K
N((T-λI)^k) = N((λI-T)^k)
T(-v) = -T(v)
N(T) = {v in V: T(v)=0} in V hence T(v) = 0 for all v in V.
we know that (T-λI)^k(-v) = -(T-λI)^k(v) = (λI-T)^k(v). So when (T-λI)^k(v) = 0 so does (λI-T)^k(v). Hence N((T-λI)^k) = N((λI-T)^k)
tinynerdi said:
T(-v) = -T(v)
You mean Tv=0 for all V in N.
You mean (T-λI)^k(v) = 0 if and only if (λI-T)^k(v) = 0.
isn't N(T) is a subspace of V since V is a vectors space.
Yeah, that is what I am trying to prove.
It looks correct. Basically, you're proving that for any linear map T, T and -T have the same kernel. This is true because Tv=0 iff -Tv=0.
Can we just state that because Tv=0 iff and -Tv = 0 therefore N((T-λI)^k) = N((λI-T)^k) or do we have to prove that Tv=0 iff and -Tv = 0?
Well, there is not much to prove. The only thing you need is that -0=0.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
