Diffraction Grating Maximum Order
To determine the maximum order of diffraction for a grating with 1000 lines per mm illuminated by sodium light at 589.3 nm, the formula m = d/λ is used, where d is the slit spacing. The slit spacing d can be calculated as 1 mm / 1000, resulting in 1 µm. Substituting the values gives m = 1 µm / 589.3 nm, which simplifies to approximately 1.695. Since the maximum integer value for m is 1, the highest observable order of diffraction is the first order, confirming that higher orders, like the second or third, cannot be achieved. Thus, the maximum order of diffraction is 1.
silence98
A grating having 1000 lines per mm is illuminated with sodium light of mean wavelength 589.3 nm. Determine the maximum order of diffraction that can be observed.
dsin(\theta)=m\lambda
d=slit spacing
The order of diffraction is given by m, and m=(dsin\theta)/\lambda, so i figure m takes a maximum value when sin(\theta)=1, or when m=d/\lambda but i am not sure if this is correct.
I'd be grateful for any hints.
Yes, the angle can't be greater than 90 degrees.
So if you put sin = 1 you will get a value for m that could be, for example, 3.4
This means you could get a 3rd order but not a 4th
thanks
