ANSYS Element Type for Stress Analysis of Protection Windows
For stress analysis of a protection window in ANSYS, selecting the appropriate element type is crucial, especially for a wide, thin sheet. Users are advised to familiarize themselves with basic ANSYS commands and techniques before attempting complex simulations, as improper setup can lead to errors during meshing. Creating nodes is typically necessary for defining geometry, but users may also explore direct volume creation methods. It is suggested to invest time in the ANSYS manual and tutorials to build foundational knowledge. Tackling advanced problems without adequate preparation can lead to significant challenges.
001fj
Hello,
I have to do stress analysis on a protection window at work but I am getting errors when meshing in ANSYS because of the element type I am choosing. The window is of course is a solid and is a wide, thin sheet. What Element Type should I use?
Also, do I need to create nodes or not? Can I just create a volume right away without creating nodes then connecting them to create an area/volume? (Sorry, I am new to this.)
Thanks a lot and I am looking forward to your replies.
You may be in a little over your head. Protection window tells me that you're going to try and do some sort of impact problem. Having no knowledge of basic ANSYS commands and techniques, I'd say that this is a bad idea.
Spend a month or so going through the manual and tutorials before trying to take on a (what is more than likely an LS-DYNA problem anyways) complex problem such as this.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
