Vector Analysis 2: Sum Formulas for Cosine & Sine
rafaelpol
Find the sum formulas for cosine and sine using vector methods.
Suggestion: use the following vectors
A= cos xi + sin xj
B= cos yi + sin yj
C= cos yi - sin yj
I actually solved the question by doing the dot product of A and B and finding the cosAB = cos (x-y). Then, I changed y to -y and obtained the other formula concerning the sum of cosines. The same thing was done with the cross product of A and B in order to obtain the formulas for sum and subtraction of sines. I am not completely satisfied with this solution, since the author gives the suggestion to use a vector C. I tried doing the dot product of A and C in order to obtain cos (x+y), but it did not work out since the length of vector C is cos(2y). Same thing happened when I did their cross product to obtain sin (x+y). I am thinking I am making some kind of geometrical mistake, but I have not found what would that be. Can anyone help me on this?
Thanks
Changing y to -y in B is the same thing as using C instead of B
I found now what was the problem (I made a mistake while calculating the module of C). Thank you very muchl
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
