Reflecting light ray between two curves in Mathematica
The discussion focuses on modeling a bouncing light ray between two parabolic curves using Mathematica. Users seek guidance on the syntax for coding reflections, including how to calculate slopes and normals at intersection points. The conversation highlights the importance of understanding graphics commands in Mathematica, such as plotting curves and drawing lines. A specific example is provided for plotting two parabolas and drawing lines between points on them. Additionally, a solution for dereferencing values from NSolve is discussed to facilitate further calculations.
interference
Hello everyone,
I am working on trying to model a bouncing light ray between two curves, and I would like to model it in Mathematica. However, I do not know what syntax or how to go about typing the code in. I tried to find examples on the Mathematica Documentation Centre but the examples there are not to relevant.
For example, I have two curves, let's say two parabolic curves one above the other. I want to simulate these as mirror and bounce a light ray between the two curves. Can anyone give me an idea on what Syntax to do it?
I understand people draw lines using the Line command, but I do not know how to proceed from there, such as how to program the line to reflect and calculate the slope and normal at the point where the light ray hits one curve and so on.
Thanks very much :)
Mathematics news on Phys.org
I don't know Mathematica, however:
If you have the equation of the line, you can find it's intersection with a parabolic surface. It's just solving a quadratic equation.
Once you have the intersection, you can find the slope of the parabola, and from that the slope of the normal at that point (taking the negative reciprocal).
Finally, since slope is the tangent of the angle of the line or normal, you can use the law of reflection to get the angle or slope of the reflected line. Since you have that slope, and a point on the reflected line, you can get its equation and find where i intersects the other surface.
Hope that helps. Feel free to ask more specific questions about the procedure I outlined here.
Hi Redbelly98, yes I do know how to find the slope and all but I need help with the syntax with which to write a code so that Mathematica and do it.
Now for example, if I use NSolve to solve for a slope at a particular place, it gives me for example x-> 0.2. Does anyone know how I can use this value to be placed into another equation? Because if I put the NSolve function into a new function to solve, Mathematica cannot do that because it reads the value not as "0.2" but as "x->0.2".
Thanks!
You need to get familiar with drawing lines and curves and just graphics in general in Mathematica.
First just draw two parabolas. Say for example:
y1=x^2+2x-1
y2=-3x^2-x+4
Then to draw those, I'd code:
myplot=Plot[{x^2+2x-1,-3x^2-x+2},{x,-5,5},PlotRange->{{-5,5},{-5,5},PlotStyle->{Red,Blue}]
That's a good start. Get a print-out of that. Now just practice drawing dots on the parabolas. Say for example, draw a green dot at the point (1,2) on the first one:
mydot1=Graphics[{PointSize[0.008],Green,Point[{1,2}]}];
Show[{myplot,mydot1}]
Draw a dot on the second one:
mydot2=Graphics[{PointSize[0.008],Green,Point[{1,0}]}];
Now draw a straight line between the two points:
myline1=Graphics[{Yellow,Line[{{1,2},{1,0}}];
Now show everything:
Show[{myplot,mydot1,mydot2,myline1}]
Or if you wanted to draw a line with just the function, use:
Plot[m x+b,{x,b1,b2}]
and to dereference that x->2, try this example and then apply it to yours:
myroots = NSolve[(x - 2) (x + 2) == 0, x]
theroots = x /. myroots
firstone = theroots[[1]]
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
