Is it possible to create a lamp that shines darkness?
  • Thread starter Thread starter Secret
    Idea Weird
The discussion revolves around the concept of creating a "lamp" that emits darkness, stemming from the idea that black represents the absence of visible light. Initially proposed as "dark photons" that annihilate light, this idea was deemed unfeasible due to the nature of photons and energy conservation laws. A modified proposal suggested using a stream of particles that convert visible light into infrared radiation, effectively dimming light without producing visible illumination. Concerns were raised about potential radiation hazards from this method. Participants explored various theoretical approaches, including noise-canceling principles applied to electromagnetic waves, and questioned the feasibility of creating safe dark emitters within the known laws of physics. The conversation also touched on advanced concepts like photon conversion to axions and the limitations of discussing science fiction scenarios.
Secret
Since 7, I always have a weird idea in mind
As light can be in any colors, then why not black
Later at 15, I understand that black = absence of (visible) light (photons)
but would it be cool if we have a lamp that shines darkness?
I once have discussed this idea with my physics teacher before.
Original idea: Something that acts like light (I'll call them Dark photons), that is the opposite of light, when the two collide, they aniliate each other, rendering the result area dark, so it'll look like a lamp that project darkness
but my physics teacher said this does not work as
1. The antiparticle of photon is itself
2. It violates the conservation of energy
Instead he modified my idea a bit and propose a new proposal
New idea: Instead of acting like EM waves, why not have a stream of particles (or even quasiparticles) that radiated from a source in all directions which converts all visible photons that collided with them into IR (simply like a frequency modifier), as IR is invisible to humans, it can produce the same dimming effect. He also think the dark emitters, if possible can have a wide variety of applications
At that moment i thought it'll be a good idea, but after some careful thoughts, i think it (the new idea) 'll pose radiation hazard to organisms (e.g. overheating, Sunburns etc.) (including humans)
Guys what do you think of it and is it possible to produce a dark emitter that is safe, using known laws of physics?
Actually, photon nullifiers have been around for a while. I have a couple in my back yard with a hammock strung up between them.
Yes turn off the lights.
build a small version of the LHC and put it on a lamp post. when you flick the switch all the mini black holes it creates will suck in nearby light (just don't walk too close)
Well, what would happen if you used noise canceling principles and superposition on electromagnetic waves in the frequency of visible light?
I think noise canceling only works because electrical signals can propagate much faster than sound waves. You couldn't cancel light, because you couldn't anticipate it in time to do anything about it.
Are there any "dark spots" in the double slit interference pattern?
Photon can be converted to axion, according to some theories.
We don't discuss scifi as a possibility.
Secret, you are aware of this from your feedback thread.
