Solving Integration Question: \int\frac{dx}{(R^{2}+x^{2})^{3/2}}
  • Thread starter Thread starter hasan_researc
    Integration
The discussion revolves around the integral \(\int\frac{dx}{(R^{2}+x^{2})^{3/2}}\), which falls under the subject area of calculus, specifically integration techniques. Participants are exploring the implications of variable substitution and the behavior of the integral as limits approach infinity.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the substitution \(x = R\tan\theta\) and its implications for the limits of integration. There are questions about the validity of changing from indefinite to definite integrals and the existence of limits as \(x\) approaches infinity. Some participants suggest reconsidering the limits for \(\theta\) based on the periodic nature of the tangent function.
The discussion is ongoing, with various interpretations being explored. Some participants have pointed out potential flaws in the original poster's reasoning regarding limits and the nature of the integral. There is a mix of suggestions for correcting the approach and clarifying the relationship between \(x\) and \(\theta\).
Participants are navigating the complexities of improper integrals versus definite integrals, noting that the original problem may require careful consideration of limits and the behavior of the integrand at infinity.
hasan_researc
\mbox{Let }x = R\\tan\theta \Rightarrow dx = R\\sec^{2}d\theta
x^{2} = R^{2}\\tan^{2}\theta
\Rightarrow R^{2} + x^{2} = R^{2}\\( 1 + tan^{2}\theta)
\Rightarrow R^{2} + x^{2} = R^{2}\\sec^{2}
\Rightarrow (R^{2} + x^{2})^{3/2} = R^{3}\\sec^{3}\theta
\mbox{Therefore, }\int\frac{dx}{(R^{2}+x^{2})^{3/2}}
=\int\frac{R\\sec^{2}\theta}{R^{3}\\sec^{3}\theta}\\d\theta
=\frac{1}{R^{2}}\\ \int^{\infty}_{-\infty}cos\theta\\ d\theta
=\frac{1}{R^{2}}\stackrel{lim}{n\rightarrow\infty} \int^{N}_{-N}cos\theta\\ d\theta
=\frac{1}{R^{2}}\stackrel{lim}{n\rightarrow\infty}(sin\theta)\mid^{N}_{-N}
=\frac{1}{R^{2}}\stackrel{lim}{n\rightarrow\infty}(mbox{sin N + sin N})
=\frac{2}{R}\stackrel{lim}{n\rightarrow\infty}mbox{sin N}
and then?
It's simply that lim_{x\rightarrow \infty} (sin x) does NOT exist.
But the integral has an answer, and it's 1!
The last lim you got doesn't exist. The wrong step here is when you changed the variable from x to theta. I guess the upper and lower limits of x are \infty and -\infty, right? The relation between x and theta is: x=Rtan\theta. Since tan is a periodic fuction, tan(theta) cannot be defined if theta=infinity. Thus, you must choose another upper and lower limits for theta.
Hint: there is an infinite number of values for theta so that tan(theta) = infinity.
If you get the right limits, you will find the integral's value is 2 (not 1).
You're on the right track here, but your argument has a flaw. The OP can undo the substitution and use the original limits of integration, or can find the new limits of integration as you are suggesting. The relationship is x = Rtan(theta). If x = infinity, that implies that Rtan(theta) = infinity, not that theta = infinity. x --> infinity if theta --> pi/2 from the left.
To the OP:
Since the integrand you ended with is cos(theta), an even function, use the symmetry of the function like this:
\int_{-b}^b f(x) dx = 2 \int_0^b f(x) dx
But there's still the problem that you're using an improper integral where you should be using an indefinite integral. There shouldn't be any bounds that you're integrating on... You can't just change indefinite to definite like that.
  • · Replies 19 ·
  • · Replies 20 ·
