Solving Problem 2-8: Relative Velocity and Time Elapses
JasonRox
I think I'm thinking to hard for this one, so I'll wait till tomorrow before checking up with you guys. I'll let my brain freshen up first. Yes, I have a "thing" for figuring it out on my own.
Anyways, it's a question from David Hogg's book, so it is NOT my homework.
Problem 2-8
Two spaceships, each measuring 100 m in its own rest frame, pass by each other traveling in opposite directions. Instruments on board spaceship A determine that the front of spaceship B requires 5x10^-6 s to traverse the full length of A.
a) What is the relative velocity of the two spaceships?
b)How much time elapses on a clock from spaceship B as it traverses the full length of A?
Now, that I typed it out, I believe I got it now, so I'll check it out later, and see you guys in 12 hours.
Thanks.
a) In the frame of A, synchronized clocks can be setup at the front and back ends of A's spaceship. Hence the speed that A measures for B is determined simply by distance / time.
b) The spaceships are symmetrical. What exactly does the phrase "traversing the full length of A" - the time it takes for the entire ship to pass by one stationary point (eg. the front) in the frame of B?
I thought the same for a).
Question b) What would the time be in B's Frame. B wouldn't measure 100m because of length contraction.
If we are right about a), than v is:
100m/5.0*10^-6 = 20,000,000m/s
To find out how much time went by for spaceship B, we use the time dilation(pythagorean) formula.
\gamma \equiv \frac{1}{\sqrt{1 - v^2/c^2}}
If I did the calculations right, for every second that passes on B, 1.00223 seconds passes on A, relative to A.
This doesn't seem like it is the answer. The question isn't clear enough.
The above question are the EXACT words out of the book, so questions relating to what does "this" actually mean I do not know anything. This is where I think too deep, and I'm sure some of you get the same problem.
I'll move on, and if something comes up, I'll try it.
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
