Inductance of a straight vs toroidal solenoid
The inductance of a long straight solenoid and a toroidal solenoid is theoretically similar, despite the longer magnetic path length of the straight solenoid. The key factor in determining inductance is the strength of the magnetic field rather than the path length. The long solenoid approximation allows for the assumption that the external magnetic field is negligible, which holds true for toroids where the field is zero outside. However, the magnetic field outside a toroidal solenoid is not entirely zero; it is present but significantly weaker. This discussion highlights the nuances of magnetic field behavior in different solenoid configurations.
htg
According to widely known formulas, the inductance of a long straight solenoid will remain practically the same if we bend it into a toroidal solenoid. It seems to be a contradiction, because the magnetic path length of a straight solenoid is more than two times greater.
The path length isn't actually important. What matters is the strength of the magnetic field.
The long solenoid approximation is used because it allows a simplifying assumption that you can ignore any field outside the solenoid as trivially small when you calculate the field inside. (using Stokes theorem and curl B = mu0 J)
In the case of a toroid, the field actually IS zero outside so the assumption becomes a fact.
The difference between the two is trivial.
I find it strange (in the light of the Gauss' law) that the flux going through the inside of a long solenoid just comes back on the outside no matter how long the solenoid is.
In the case of a toroid, I don't think the field on the outside is zero - it is not confined to such a small volume, so its intensity is much smaller.
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
