Embedded Systems: Electrical Engineering Basics & User Interface
The discussion revolves around a project involving a mechanical device with an inductive heater controlled via a user interface. The individual is new to electrical engineering and seeks guidance on the use of microcontrollers, embedded software, and necessary physical components. Recommendations include starter kits from various sources that provide hardware and software, as well as insights into embedded operating systems. Specific suggestions for microcontrollers, such as the PIC 16F818, are provided, emphasizing the importance of hiring knowledgeable professionals for the design work. Overall, the conversation highlights the need for foundational resources and expert assistance in developing the project.
dsambo
Hi, I am working on a project but I am new to electrical engineering. The project is going to be a mechanical device with an inductive heater controlled through a console with software to receive inputs for the settings through a user interface. I have read about microcontrollers and their uses but I am not sure how they work in a real system i.e. if you need multiple microcontrollers for different functions.
I also need some clarification on how embedded software works as well as the physical components that need to be designed in order to use the software.
This project is just an idea so far but I am working on making it tangible any help, information, or reference will be greatly appreciated.
Start here http://www.practicalarduino.com/
The book is about $30, as is the circuitboard+micro
Thanks for the response. However, because I am inexperienced in electrical engineering the design work is going to be done by someone else I am just looking for individual parts. I will browse through their website and see what it is about.
A starter kit that include hardware and software could be quit helpful. I myself started learning embedded systems with a starter kit from http://www.arm9board.net" , their kits typically come with Demos for embedded OSes like Embedded Linux, Windows CE, Android, uCos/II, and a plenty of sample applications with detailed comments. By looking into these source code and their documents you may learn a lot about the systems.
Another hobbyist site is Sparkfun Electronics, who have a range of controller boards that might save you the hardware development time:
http://www.sparkfun.com/commerce/categories.php
If you insist on doing it yourself look at the PIC micro-controllers from MicroChip:
http://www.microchip.com/ParamChartSearch/chart.aspx?branchID=1002&mid=10&lang=en&pageId=74
With a the few inputs and just a couple outputs you need, one of the PIC 16 pin chips like the 16F818 could work. Presuming that you are hiring someone who knows what they are doing to execute this part of your plan, they _should_ know this already...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
