Question about flow of electrons and electric current
The discussion centers on why electric current is defined as flowing in the opposite direction to electron flow. It highlights that early theories of electricity assumed the flow of positive charges, leading to the convention of defining current in that direction. Although it was later discovered that electrons, which carry negative charge, are the actual charge carriers in conductors, the original terminology was retained for consistency. Historical figures like James Clerk Maxwell contributed to this understanding, despite initially guessing the direction of flow incorrectly. Ultimately, the established convention persists for practical reasons in calculations and communication.
Taturana
Why is the electric current in the opposite direction of the flow of electrons?
One may say: "Oh, because the electric current represents the flow of positive charges"...
Okay, but why don't the theory use the electric current representing the flow of negative charges?
I heard from a professor that it is because in the beginning of the study of electricity "they" used to think that the electric current was caused by the flow of positive charges... then later they realized that it was caused by the flow of electrons (in the solid conductors) and then to don't remake the theory and to don't need to rewrite everything that was writen, they defined electric current as the flow of positive charges... (this was done because the direction of the flow of electrons does not make different for calculation purposes)... is my professor right?
Thank you,
Rafael Andreatta
I think it is due to convention. Usually things go from high to low. High would be considered positive. I am just guessing though.
Rafael Andreatta
Yes.
Electricity was discovered long before anyone had any idea that electrons even existed.
No-one could tell which way it was flowing - in fact there was a big argument about whether it was one thing flowing one way or two things flowing both ways.
James Clerk Maxwell decided it was probably just one thing and made a guess which way it flowed - he got it wrong!
Here's the book he wrote. If you ignore all the complicated maths it's interesting to read how he thought about it.
http://www.archive.org/stream/treatiseonelectr01maxwrich#page/n5/mode/2up"
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
