Charge Distribution from Known Potential - Induced on Surface of Metal Sphere
bjnartowt
Using the method of images: discuss the problem of a point-charge “q” inside a hollow, grounded, conducting-sphere-shell of inner radius “a”. That charge "q" is located at {\left| {{{{\bf{\vec r}}}_0}} \right|}. We don't care about its angular position. Oh yes: the problem is two dimensional: as you will see, potential is termed as r, theta dependent.
(b) Find the induced surface-charge density. The potential is known to be:
\Phi (r,\theta ) = \frac{q}{{4\pi {\varepsilon _0}}}\left( {\frac{1}{{\sqrt {{r^2} + {{\left| {{{{\bf{\vec r}}}_0}} \right|}^2} - 2r\left| {{{{\bf{\vec r}}}_0}} \right|\cos \theta } }} - \frac{a}{{\sqrt {{r^2}{{\left| {{{{\bf{\vec r}}}_0}} \right|}^2} + {a^4} - 2r\left| {{{{\bf{\vec r}}}_0}} \right|{a^2}\cos \theta } }}} \right)
Surface charge density: it’s derived from integral Gauss’s Law:
\int {{\bf{\vec E}} \bullet d{\bf{\vec A}}} = \frac{Q}{{{\varepsilon _0}}}{\rm{ }} \to {\rm{ }}{\bf{\vec E}}(r,\theta ) = \frac{Q}{{{\varepsilon _0}\int {d{\bf{\vec A}}} }} = \frac{{\sigma (r,\theta )}}{{{\varepsilon _0}}} [I.2]
And: curl-less-ness of electric field:
{\bf{\vec E}} = - \vec \nabla \Phi [I.3]
Then: [I.2] and [I.3] give the surface-charge density as a function of the potential we derived as:
\sigma = - {\varepsilon _0}\left| {\vec \nabla \Phi } \right|
The spherical gradient operator reduced to polar coordinates:
\vec \nabla = {\bf{\hat r}}\frac{\partial }{{\partial r}} + \hat \theta \frac{1}{r}\frac{\partial }{{\partial \theta }}
Umm…I feel like I’m doing this really wrong. Never have I needed to use the "theta-hat" in computation…only in conceptually grasping the field of a dipole.
Then: someone tells me to use:
\sigma = {\left. {{\varepsilon _0}\frac{{\partial \Phi (r,\theta )}}{{\partial r}}} \right|_{r = a}}
But I disagree: neither the charge distribution nor the potential are symmetric in "theta". Surely: as you "tilt through theta" away from the charge hovering outside the metal sphere: the charge will go from positive to negative when you've gone from theta = 0 (right under the charge) to theta = pi (on the opposite pole of the metal-sphere, away from the charge)?
No, \int\textbf{E}\cdot d\textbf{A} = \textbf{E}\cdot\int d\textbf{A} not \textbf{E}\int d\textbf{A}, and only in the case where \textbf{E} is uniform/constant over the surface. And, \textbf{a}\cdot\textbf{b}= c does not mean that \textbf{a}=\frac{c}{\textbf{b}}
"someone" is correct. The equation comes from the boundary conditions on the \textbf{E}-field as it crosses a surface. The component of the normal \textbf{E}-field that is perpendicular to the surface will be discontinuous by an amount \frac{\sigma}{\epsilon_{0}} (this is likely derived in your textbook directly from Gauss' Law, and I strongly recommend you read that section of your text).
I think I see it. The field discontinuity across a charged surface is:
{{\bf{\vec E}}_{above}} - {{\bf{\vec E}}_{below}} = \sigma /{\varepsilon _0}
...in which you use the field/potential relation:
{\bf{\vec E}} = - {\mathop{\rm grad}\nolimits} (\Phi )
...to get what "someone" told me:
\sigma = - {\varepsilon _0}\frac{{\partial \Phi }}{{\partial r}}
...and I'm just the short distance of "plug-n'-chug" away from a possibly-correct charge density. No?
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
