What is the Locus of Re[z^2]>1?
  • Thread starter Thread starter Grand
    Complex
The locus of Re[z^2]>1 can be derived by substituting z=x+iy, leading to the inequality x^2-y^2>1. This represents the region outside the hyperbola defined by the equation x^2-y^2=1. Testing points like (0,0) and (2,0) confirms the behavior of the graph. The discussion emphasizes that understanding the graph's shape is key to solving the problem. Ultimately, the solution involves recognizing the hyperbolic nature of the inequality.
Grand
Find the locus of Re[z^2]>1
Subbing in z=x+iy gives x^2-y^2>1, but where do I go from there on. It shouldn't be very tough (i.e. including analysis of functions) because the other examples in the same problem are easy.
Well can you graph x^2-y^2=1? It should be clear where it is more than 1 either by intuition or testing some easy points such as (0,0) versus (2,0).
It is the graph of a hyperbola by the way.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
