How can I solve a three-box system force problem?
  • Thread starter Thread starter Ilyo
    Force Systems
To solve the three-box system problem, start by drawing free body diagrams for each box to visualize the forces acting on them. The applied force of 100N on the first box (m1) results in a shared acceleration for all boxes, as they are in contact and move together. The net force on each block can be determined using the equation sigma F = ma, focusing only on horizontal forces since the surface is frictionless. It's important to note that normal forces do not act on the end of the last box; instead, the force from the adjacent box propels it forward. Understanding these concepts will clarify how to approach the problem effectively.
Ilyo
three boxes are slid across a frictionless surface, 100N is applied to m1(mass1) which is pushed against m2 and m3 each box weighs 10 kg
a draw a free body diagram for each box
b find the acceleration of the system
c the net force on each block
d the force of contact that each block exerts on its neighbor
[sigma]F=ma
Well I have drawn my free body diagrams
then I set up my equation for part b
though I am not sure where to go from there I was hoping somone could show me how to do the rest of the problem with different values than the ones I was given, and explain how they did it so I can get a better grasp on what to do here..
{now since it is a frictionless surface and a normal force pushes back as much as is applied to it would the third objects normal force be 100 Newtons? If so then it would be really simple and turn out to bed
NF=ma
100=10a} <---I understand this is wrong...
I feel way off track?
Thanks for your insights
Make a picture with a drawing program and upload as attachment.
Draw the normal forces in your figure. The boxes are in contact, so they move together with the same acceleration. Apply sum(F) =ma for each block.
ehild
fixed...
The first block is pushed with Fa. Fa can not act between two blocks.
Two boxes act to each other with forces of equal magnitude and opposite directions.
The boxes move on a horizontal surface, their weight, mg, cancels with the normal force of the surface. You need to work only with the horizontal forces .
There is no normal force at the free end of the third box.ehild
if there is no normal force at the end of the last box then what is pushing it forward?
The other box at the other side.
ehild
right right.. I think I got it now thanks ^^
