How can I reduce this expression to e^{mx}?
  • Thread starter Thread starter Saladsamurai
    Algebra Figure
The discussion revolves around simplifying the expression A = (e^{mx} - e^{2ml - mx}) / (1 - e^{2ml}) to A = e^{mx}. Participants suggest that the original poster may have a sign error in the exponent of the numerator. After correcting the expression to A = (e^{mx} - e^{2ml + mx}) / (1 - e^{2ml}), the simplification becomes clearer. The final steps show that factoring out e^{mx} leads directly to the desired result. The conversation emphasizes the importance of careful attention to signs in exponential expressions.
Saladsamurai
I at a point in a derivation where I have the expression:
A = \frac{e^{mx} - e^{2ml - mx}}{1-e^{2ml}}
I have double checked my work leading up to this point, so i am confident my expression for 'A' is correct. I am supposed to reduce it to
A = e^{mx}
but I am not seeing the trick here. I have tried numerous approaches from factoring the denominator and various arrangements of the numerator. I have a feeling it is one of those random tricks i need. Any thoughts?
I think you might have a sign error in the exponent on the first term in the numerator.
Assuming this is the case for the moment, you have
A = \frac{e^{-mx} - e^{2ml - mx}}{1-e^{2ml}}
= \frac{e^{-mx} - e^{2ml}\cdot e^{ -mx}}{1-e^{2ml}}
= \frac{e^{-mx}(1 - e^{2ml})}{1-e^{2ml}} = e^{-mx}
A = e^{-mx}
A = e^{-mx}
I'm sorry it's supposed to come out to be a positive exponent. That is,
A = e^{mx}
I have edited OP.
In that case, I think your error is in the second term in the numerator.
A = \frac{e^{mx} - e^{2ml + mx}}{1-e^{2ml}}
= \frac{e^{mx} - e^{2ml}\cdot e^{ mx}}{1-e^{2ml}}
= \frac{e^{mx}(1 - e^{2ml})}{1-e^{2ml}} = e^{mx}
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
