Sanding Table Design: Pneumatic Mechanism Overkill?
  • Thread starter Thread starter Jones1987
    Design Table
The discussion centers on the design of a sanding table mechanism that oscillates left and right, with the suggestion of using a pneumatic mechanism. While pneumatic systems could effectively achieve the desired motion, they may introduce unnecessary complexity depending on the specific application and power sources available. The choice between pneumatic and electric systems should consider the existing power distribution in the workspace. Ultimately, the decision hinges on the context of the project, whether it is for work or educational purposes. Understanding the operational environment is crucial for selecting the most appropriate mechanism.
Jones1987
So I've been handed an assignment, to design the mechanism and structure to oscillate a sanding table left and right. I thought about strapping a pneumatic mechanism underneath, a rod would connect to clamps which are attached to the board. My question is, would a pneumatic mechanism be a bit overkill?
I can't believe that no one has responded to this yet. I've been holding off because I expected some experts to weigh in.
First off, I don't know whether this assignment is a work project or homework from school. Either way, I'm not going to solve it for you, nor will anyone else here. You have to earn the benefits, whether they be salary or marks.
As a simple answer to your question, pneumatics would not be overkill, but might be overly complex for the task. It depends upon several factors. One of those is what the primary power distribution in your location is like. For instance, in the factory where I worked back in the mid-70's, all of the machinery was driven by air motors from one honkin' huge compressor. In a situation like that, it would be expedient to tap an air line and use the pneumatic actuator. If your shop is primarily electric, though, it might be better to go that way.
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
