Identifying Removable Discontinuities in Rational Functions
  • Thread starter Thread starter eit2103
    Discontinuity
eit2103
Hi all,
My first message here.
I had the following question in a quiz:
For each of the following determine all x values where the function has a removable or non-removable discontinuity and identify whether the discontinuity is a hole, jump or vertical asymptote.
1. f(x) = |x - 3|
_____
x - 3
My answer:
hole at x = 3
My teacher deducted 2 points noting down "why?"
frankly, I don't understand what he meant by why? Why what?
Looking forward for your suggestions.
I would have deducted all the points on that problem because your answer isn't even correct, let alone having explained why. Do you know the difference between a jump discontinuity and a removable one? Have you looked at the graph of your function?
Take LCKurtz's advice and graph the function, and you should see why the discontinuity isn't removable.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
