What is the angle of a suspended rod supported by two springs?
A uniform 1.3-kg rod, 0.71 m long, is suspended by two springs with different spring constants (57 N/m and 32 N/m). The initial attempt to find the angle with the horizontal involved calculating the stretch of each spring individually, leading to an incorrect angle of 14.19 degrees. The error was due to not accounting for the fact that both springs share the weight of the rod. By dividing the gravitational force by two, the correct approach was established, resulting in the correct angle. The discussion highlights the importance of considering shared forces in systems with multiple supports.
cegraves
A uniform 1.3-kg rod that is 0.71 m long is suspended at rest from the ceiling by two springs, one at each end of the rod. Both springs hang straight down from the ceiling. The springs have identical lengths when they are unstretched. Their spring constants are 57 N/m and 32 N/m. Find the angle that the rod makes with the horizontal.
Fx=kx
I tried to determine the difference in the lengths of the two stretched springs using the spring constants and the mass of the rod.
(1.3kg)(9.8m/s2)=(57N/m)(x), x=0.224m
(1.3kg)(9.8m/s2)=(32N/m)(x), x=0.398m
I used the difference, 0.174m, and the hypotenuse, 0.71m, to make a triangle and solve for the angle using the function sin-1(0.174/0.71) to find the angle with the horizontal. The solution I got was 14.19o, which was incorrect.
The springs share the weight of the road, so your equations are not true.
ehild
Okay, so I divided the force due to gravity by 2 and worked through the problem and got the answer. I hadn't considered that the springs would share the restoring force. Thanks for the help!
