Solving Rotations Homework: Double Speed vs Halving Radius
  • Thread starter Thread starter baobao11
    Rotations
The discussion focuses on the effects of doubling speed versus halving the radius on a truck's acceleration around a circular track. Using the equation a = v^2/R, calculations show that doubling the speed from 15 m/s to 30 m/s results in an acceleration of 9 m/s^2, while halving the radius from 100 m to 50 m yields an acceleration of 4.5 m/s^2. The consensus is that doubling the speed has a greater impact on acceleration than reducing the radius. This is confirmed by the principle that any factor multiplied to velocity affects acceleration quadratically. Overall, the conclusion is that increasing speed significantly enhances acceleration more than decreasing radius.
baobao11
A truck was driven around a circular track. Which would have a greater effect on the magnitude of its acceleration: moving to a track with half the radius or doubling the speed.
Show proof/sample calculations.
I'm not quite sure but I went ahead and tried this equation:
a = v^2/R
I tried plugging in numbers:
a = v^2/R
v= 15m/s
R = 100m
a= (15^2)/(100) = 2.25 m/s^2
doubled speed:
a= (30^2)/100 = 9 m/s^2
half radius
a = (15^2)/50 = 4.5 m/s^2
If I'm correct, doubling speed will affect the magnitude of the acceleration more than the halved radius, right?
Thank you so much!
Yes that is correct since whatever factor you multiply the velocity by, becomes squared as well.
a=v2/r
if 'v' is replaced by 'kv', then a' = k2 (v2/r) = k2a
a=v2/r
thank you very much for confirming my answer! :smile:
