What affects the solubility of CaSO4 in different solvents?
The discussion centers on the solubility of calcium sulfate (CaSO4) in water and the implications of solubility constants, specifically Ksp. Initially, Ksp is defined as the product of the concentrations of calcium and sulfate ions. However, the presence of activity coefficients (γ) in the Ksp equation indicates that the behavior of ions in solution is influenced by the activity of water and electrostatic interactions. The conversation highlights that in nonpolar solvents, where the dielectric constant is low, the interactions between ions increase, leading to significant changes in activity coefficients with concentration. It emphasizes that without considering activity coefficients, the Ksp equation may only apply to infinitely diluted solutions, suggesting that the context of solvent polarity is crucial for understanding solubility behavior.
chmmr
Say I've got a solid lump of CaSO4 that I put into water.
When I first learned about Solubility Constants, Ksp was defined as [Ca][SO4], meaning how much Calcium and Sulfate ions dissolved. But now I found out when I look up a Ksp value it is [Ca][SO4]\gammaCa\gammaSO4. I understand the concept of activity, that those new constants take into account the activity of the water on the ions. So does this number just mean how much of the CaSO4 would dissolve in a nonpolar solvent?
Chemistry news on Phys.org
It is not about activity of the water, it is about electrostatic interactions between ions. In nonpolar solvents (with low dielectric constant) interactions between ions are much higher, so the activity coefficients will change much faster with concentration.
I don't think it makes much sense to try to assign a special meaning to the equation without activity coefficients (or more precise - with activity coefficients equal 1). The closest thing I can think of is a border case of infinitely diluted solution.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
