Proving Mean Value Inequality for sin(x) on 0≤x≤1 and 0≤y≤1
absci2010
Show that 1/2(1-cos1)\leq\int\intsinx/(1+(xy)4)dxdy\leq1 on the area 0\leqx\leq1, 0\leqy\leq1.
Mean Value Inequality: m*A(D)\leq\int\intf(x,y)dA\leqM*A(D), where m is the minimum and M is the maximum on the interval.
A(D)=1
sinx\leq1, sinx/(1+(xy)4)\leq1, so M=1
I tried to find the minimum on the interval, but I can't find any critical points that are in 0\leqx\leq1 and 0\leqy\leq1.
Please help?
I have not worked this question out, but I suspect you need something more than mA(D) as a minimum. When you plug in x = 0 and y = anything in D, you find a minimum value of 0.
If there are no critical points, the minimum should occur somewhere on the boundary.
Yes, but that's the part I'm confused about. Where does the value (1/2)(1-cos1) come from?
If you look hard enough at that quantity, you might be able to guess at a g(x,y), such that
g(x,y)\leq f(x,y), ~ (x,y)\in D,
for which the integration is elementary.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
