Purcell - Electricity and Magnetism
The discussion centers on finding a hardcover copy of the 1985 edition of "Electricity and Magnetism." While institutions like Caltech and MIT still utilize the book, it is not available in Caltech's online bookstore, and MIT only offers a newer edition, likely in ebook format. Some listings on Amazon are priced around $400, which is considered too expensive for many. A suggestion is made to use www.allbookstores.com, a site that aggregates listings from numerous online retailers, to search for used copies. It is noted that the second edition was released in 1984, implying that any later edition is merely a reprint and should suffice for those seeking a more affordable option.
intwo
Does anyone know where I can purchase the hardcover 1985 Electricity and Magnetism? Some schools, such as Caltech and MIT, still use the book; however, Caltech does not have it in their online bookstore and MIT lists an 09 edition (which I assume is an ebook?).
Some copies are floating around on Amazon for around $400, but that's out of my budget.
Thanks!
I allways look at:
for used books. It searches a gazillion online retailers. Note that the 2nd edition of Purcell came out in 1984, so any edition after that is just a reprint and should be fine. I suspect you will find copies for << $400.
Good luck,
jason
The book is fascinating. If your education includes a typical math degree curriculum, with Lebesgue integration, functional analysis, etc, it teaches QFT with only a passing acquaintance of ordinary QM you would get at HS. However, I would read Lenny Susskind's book on QM first. Purchased a copy straight away, but it will not arrive until the end of December; however, Scribd has a PDF I am now studying. The first part introduces distribution theory (and other related concepts), which...
I've gone through the Standard turbulence textbooks such as Pope's Turbulent Flows and Wilcox' Turbulent modelling for CFD which mostly Covers RANS and the closure models. I want to jump more into DNS but most of the work i've been able to come across is too "practical" and not much explanation of the theory behind it. I wonder if there is a book that takes a theoretical approach to Turbulence starting from the full Navier Stokes Equations and developing from there, instead of jumping from...
