Symmetric Matrix and Definiteness
MikeDietrich
If A is a symmetric matrix, what can you say about the definiteness of A^2? Explain.
I believe I need to use the face that A^2=SD^2S^-1.
I know that if all the eigenvalues of a symmetric matrix are positive then the matrix is positive definiteness and if the eigenvalues are positive and zero then the matrix is semidefinite.
Not sure where to go from here.
So, we need to show that A2 is positive definite? What does this mean?
I don't know if A^2 will be positive definite. Oh, wait... if A^2= SD^2S^-1 then the diagonal matrix squared will only give positive or zero eigenvalues so A^2 will be positive semidefinite unless A is invertible then it would be positive definite. Do I have to worry about the orthogonal matrix and its inverse?
Yes, A2 will always be positive definite, unless A is zero...
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
