Buckling Energy of Beam/section
  • Thread starter Thread starter Su Solberg
    Buckling Energy
Estimating the energy required to buckle a hollow tube can be approached through calculations involving critical load and axial deflection. The critical load for buckling is defined by the formula F=π²EI/L_eff², where L_eff is the effective length. Axial deflection can be calculated using δ=FL/AE, and the moment of inertia for a hollow tube is given by I=π(r_o⁴-r_i⁴)/2. The strain energy from axial loading up to the critical buckling load can be expressed as a derived formula that incorporates these variables. This information is essential for calculating the backstay of a cane to ensure it withstands rebound forces during abnormal operations.
Su Solberg
Hi guys, I wonder whether we can roughly estimate the energy used to buckle a hollow tube (by calculation)?
I was asked to calculate the backstay of a cane to ensure it can stand for the rebound force due to abnormal operation.
Thanks in advance.
It is easiest to calculate the minimum energy required to achieve buckling. The critical load F for buckling a long, slender object is F=\pi^2EI/L_\mathrm{eff}^2 (where L_\mathrm{eff} is the effective length for the loading condition you're interested in). The axial deflection \delta from an axial load is, as usual, \delta=FL/AE, and the moment of inertia for a hollow tube is I=\pi(r_\mathrm{o}^4-r_\mathrm{i}^4)/2. So the strain energy from axial loading up to the level of the critical buckling load is
\frac{1}{2}F\delta=\frac{1}{2}\left(\frac{\pi^4E^2I^2}{L_\mathrm{eff}^4}\right)\left(\frac{L}{AE}\right)=\frac{\pi^5E(r_\mathrm{o}^4-r_\mathrm{i}^4)(r_\mathrm{o}^2+r_\mathrm{i}^2)L}{8L_\mathrm{eff}^4}
which may be of some use.
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
