What causes Nitroglycerin to detonate while thawing?
  • Thread starter Thread starter workinprogres
Nitroglycerin, a highly sensitive explosive, poses significant risks during transport, particularly when frozen. The primary concern is that upon thawing, if the nitroglycerin cracks, it can detonate due to its shock sensitivity. The process of freezing and thawing can create internal stresses in the material, leading to cracks. When these cracks occur, they can trigger a detonation, similar to how an ice cube may crack when held in a warm hand. Understanding these properties highlights the dangers associated with handling nitroglycerin, especially in its frozen state.
workinprogres
While reading about Nitroglycerin a number of time I've read that it used to be frozen for transport but upon thawing it would detonate. What causes this to happen? It it expansion of the liquid as it heats up creating pressure? I have absolutely no intention or would ever consider making/buying/freezing nitroglycerin, I'm just curious.
Chemistry news on Phys.org
If it cracks while thawing, the shock sensitive material can detonate. Take an ice cube out of the freezer and hold it in your hand. Did it crack?
boom!
Wow I'm retarded *facepalm* Thanks you!
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
