Momentum - two cars crashing at an angle
The discussion revolves around calculating the initial velocity of a 2000 kg car before it collides with a stationary 1200 kg car, given their post-collision velocities. The initial calculations for momentum in both the X and Y directions were presented, but the user encountered discrepancies in their results. A key suggestion was made to correct a sign error in the Y direction calculations, which would help achieve the expected final velocity of 81.2 km/h. Additionally, it was advised to maintain consistent units, preferring km/h over m/s for clarity. The conversation emphasizes the importance of careful attention to detail in physics calculations.
XxphysicsxX
:cry:
A 2000 kg car strikes a staitionary 1200 kg car and rebounds at 65.0 km/h@ 20 (deg) Sof E. After collision, the 1200 kg car moves at 40.00 km/h @ 35(deg) N of E. Determine the velocity of the 2000 kg car before the collision.
m1= 2000 kg
V1(before) = ?
V1(after) = 18.05 m/s
M2= 1200 kg
V2(before) = 0 m/s
V2 (after) = 11.11 m/s
MV(before) = MV(after)
Momentum.
In the X direction:
momentum of object 1 (before)= M1V1a + M2V2a - M2V2b
= (2000)(18.5)(cos 70) + (1200)(11.11)(cos 35) - (0)
= 23267. 855
In the Y direction
= (2000)(18.05)(sin 70) + (1200)(11.11)(sin 35)
= 41569.82
C^2 = A^2 + B^2
C =ROOT [(23267. 855^2) + (41569.82 ^2)]
C = 47638.67 = momentum
momentum / mass = velocity
47638.67 / 2000 kg = 23.81 m/s
23.81 m/s= 85.71 km/h <<<<<<<<<<<< which is wrong... its supposed to be 81.2 km/h
... and i don't get the right angle either.
Ive been at this for two days any help will be greatly appretiated
You have a mistake in the y direction; missing a minus sign on one of the mv's. One is north, the other south. Then partially cancel, reducing the answer. It works out to 81.2 for me.
Probably not a good idea to convert to m/s since the question and the answer are in km/hr.
thankyou so muchhh!
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
