How can trigonometric identities be used to simplify complex expressions?
  • Thread starter Thread starter zeion
    Simplify Trig
The discussion revolves around the use of trigonometric identities to simplify the equation cosx - cos2x + cos3x = 0. Participants explore various approaches to manipulate the expression using known identities.
  • The original poster attempts to understand the reasoning behind grouping terms and using identities like the double angle identity. Some participants suggest substituting cos x with t to form a polynomial equation, while others question the necessity of this approach and express uncertainty about the use of inverse trigonometric functions.
Participants are actively discussing different methods to approach the problem, with some providing insights into the use of trigonometric identities. There is no explicit consensus on the best method, and multiple interpretations of the problem are being explored.
Some participants note that they have not yet covered inverse trigonometric functions in their studies, which may limit their ability to follow certain suggested approaches. Additionally, there is mention of needing to know specific angles by heart for certain solutions.
zeion
I need to solve this:
The solution shows something like:
(cosx + cos3x) - cos2x
Then using the sum to product on the first group and double angle on the cos2x.
I would know to use double angle identity somewhere, but I would not think of grouping the first 2 things. Just wondering if there's an easier way? Or what kind of mindset or goal should I have to solve something like this? It seems rather arbitrary.
Thanks.
Remembering that [tex]\cos 2x = 2 \cos^2 x - 1[/tex] and that [tex]\cos 3x = 4 \cos^3 x - 3 \cos x[/tex] (the proofs for these identities are not difficult), your equation becomes
[tex]\cos x - (2 \cos^2 x - 1) + 4 \cos^3 x - 3 \cos x = 0[/tex]​
and you do a substitution, [tex]\cos x = t[/tex] which yields a polynomial equation in [tex]t[/tex], you solve this equation and then you take the inverse of [tex]\cos x[/tex], [tex]\arccos t[/tex] to get your angles.
I don't think that's much easier than the solution I posted...
I haven't covered inverse of trig functions yet at this point of the book. Only the major trig identities.
Have a go at it. I just solved it and the results that show up are angles that you need to know by heart.
But if you are given some of the trig ratios you should be able to get the angles. For instance, if I were to ask you to find theta if
[tex]\sin \theta = \frac{1}{2}[/tex]
and 0 ≤ θ < 2π, then you should be able to tell me that
[tex]\theta = \frac{\pi}{6}, \frac{5\pi}{6}[/tex].
BTW, the cubic that Metaleer gave factors pretty easily.
