Questions regarding temperature gradient in thermocouples.
A temperature gradient is essential for thermocouples to generate an electromotive force (emf). To maintain this gradient, one side of the thermocouple should be exposed to a different temperature, such as ambient air, rather than being fully immersed in a constant temperature environment like boiling water. In applications like boilers, attaching the thermocouple to an external surface can help preserve the necessary gradient. Additionally, resistance temperature detectors (RTDs) can be utilized in scenarios where thermocouples are not suitable. Understanding these principles is crucial for effective thermocouple application.
f_nosferatu
Hi folks!
I was wondering if anyone can help me with a problem I'm having with the concept of thermocouples.
If I understand correctly, there should necessarily exist a temperature GRADIENT in one of the conductive couples in order for the emf to be generated. So how can you make sure that such a gradient exists in your application? I mean, imagine a TC used in a boiler with constant T. Won't the heat eventually propagate through the whole TC and eliminate the temperature gradient?
Some help will be much appreciated.
Thanks!
You are correct that there must be a temperature gradient.
The usual way we achieve that is to leave one side of the thermocouple exposed to ambient temperature air. In the boiler case, we could attach a termocouple to the outside wall, but not immerse it in the boiling water.
Other devices, such as the RTD can be used in places where thermocouples can not.
Thread 'I need a concave mirror with a focal length length of 150 feet'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
