What Value of d/a Causes Diffraction to Eliminate the Third Bright Side Fringe?
In a double-slit system, the discussion centers on determining the values of d (slit separation) and a (slit width) that result in the elimination of the third bright side fringe due to diffraction effects. The relevant equations include the intensity formula I(θ) and the conditions for maxima and minima in both interference and diffraction patterns. The problem involves setting d sinθ equal to 3λ for the third maximum and a sinθ equal to (3 + 1/2)λ for the first minimum. A participant expresses confusion about connecting the equations and calculating the correct ratio of d/a, which is initially found to be incorrect. The key point is recognizing that the angle θ must satisfy both the interference and diffraction conditions simultaneously to eliminate the fringe.
Zhalfirin88
(a) In a double-slit system, what value of d/a causes diffraction to eliminate the third bright side fringe?
I(\theta) = I_mcos^2(\beta)(\frac{sin(\alpha)}{\alpha})^2
\beta =\frac{\pi d}{\lambda} sin \theta
\alpha = \frac{\pi a}{\lambda} sin \theta
d sin\theta = 3 \lambda
a sin\theta = (3+\frac{1}{2}) \lambda
I solved for a and d in equations 4 and 5 above and got a ratio of 0.857, which isn't right. I'm not sure really how to go about this, I have a feeling that I need to use equations 2 and 3 but I'm not making the connections.
Is everyone as lost as I am with this problem?
Yes, the angle θ corresponds to the 3rd maximum (not counting central max) in the 2-slit interference term cos2β
Actually, the idea here is that θ also corresponds to the first minimum of the diffraction term [(sinα)/α]2
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
