Calculating Uncertainty in Averages for Scientists
  • Thread starter Thread starter spikethekitty
    Uncertainty
In the discussion about calculating uncertainty in averages for the Franck-Hertz experiment, the user seeks guidance on determining the uncertainties associated with the differences between minimum values A, B, C, D, and E. The values and their respective uncertainties are provided, and the user aims to calculate the average of these differences. The "sum of squares" rule is mentioned as a method for calculating uncertainty, along with a simpler approach that sums the maximum deviations. The conversation highlights the importance of accurately propagating uncertainties in scientific measurements. Properly applying these methods will enhance the reliability of the experimental results.
spikethekitty
In my lab we are doing Franck Hurtz experiment with heated mercury and electron beams. We already took data but i need a little help. I have the locations of the minimums A B C D and E, and each point has it's own uncertainty. a b c d and e. What i needed to find was the difference between each min and the next, so A-B, B-C... and then find the average of each these differences. I don't know how to do the uncertainty for my calculations.
My actual values are
1.4
1.94
2.43
2.98
3.66
With uncertanities (in order)
0.003686
0.008077
0.002263
0.009459
0.003834
I would say that the most general rule is the "sum of squares" rule,
(\Delta d)^2 = (\Delta x)^2 + (\Delta y)^2
where d = x - y is the difference of two independent quantities x and y.
However, I think that
(\Delta d) = (\Delta x) + (\Delta y)
is also commonly used, giving the "rough" estimate that the deviation from the mean is at most the sum of the two maximal deviations.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
