Solar Reactor using water tubes & dish collector.
The discussion focuses on the feasibility of using a fixed roof-mounted parabolic dish collector to heat water tubes for a solar reactor. Concerns are raised about whether the tubes can achieve sufficient heat at the focal point without a heliostat and if they can reach boiling temperatures when not directly at the focal point. The design involves a tube bundle rated for high pressure and temperature, intended for use in a water tube boiler system that includes superheating and turbine integration. Participants note that overheating may not be an issue if the tubes remain filled with liquid water, which would prevent temperatures from exceeding boiling. Overall, the effectiveness of the design hinges on the geometry of sun positions and the ability to concentrate heat efficiently.
BillThompson
Hi,
The dish is roof mounted and fixed.
I want to heat water tubes coming from the base up to the focal point and I'm needing to know if this is sound or a tube coming from the base will never get enough focal point to heat it because it's fixed and not on a heliostat.
Or, does the water tube get enough solar radiation when not at focal point to heat it to boiling?
I'm using a tube bundle, a replacement part in heat exchangers. They come 24" to 120" long.
They have many tubes with each tube rated at 150PSI and 375F.
My plan is to use the water tube boiler design and run the water tubes through the solar dish receiver but up from the base, not suspending it.
This type of tube bundle has two sets of twin tubes that are U shaped and just basically go in and out. I planned to use one set of tubes for the water feed drum to the tube bundle and then to the steam drum boiler. The second set of tubes are feed from the steam boilers and run back through the tube bundle and I planned to use them as a superheater and then feed to a turbine. Then from the turbine to condenser back to feed drum.
My thoughts about problems.
The tubes are rated at 375F and the tubes may melt or fail from the high temperature heat at focal point.
The excess tubing may just defuse the heat energy.
The design is basically the solar hot water heater using a parabolic collector rather than a panel of tubes collecting solar radiance.
Any comments positive or negative are welcome.
Sounds like you said, the dish would be no use without a heliostat. You could work out from geometry what range of sun positions would have the light reflected onto the tubes. Then you might get enough high temperature for few minutes a day. It sounds like your purpose is to generate power so you need high temperature in a small volume of water, rather than a lot of water at medium temperature?I have a conventional solar water heater that can go up to about 80degC in the summer. But only with some leftover hot water from the day before.
I wouldn't worry about the tubes overheating as long as they're always filled with liquid water. That'll keep their temperature to not much more than boiling point.
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
