Cantilever Beam, Tapered in breadth, uniform thickness, natural frequency
To find the natural frequency of a cantilever beam that is tapered in breadth but has a uniform thickness, the second moment of area must be expressed as a function of the angle from the z-axis. The approach involves modeling the beam as a massless structure with a point mass at the end, applying the stiffness of the beam and the point mass to derive the fundamental frequency using the formula ω = √(k/m). It is suggested to explore known formulas for the vibration of disks, particularly those involving Bessel functions, while considering the implications of Poisson's ratio. The final goal is to create an equation for frequency as a function of the angle, which can be plotted in MATLAB. This methodology provides a foundation for analyzing the beam's dynamic behavior.
jazzkiwi
Hey there
I need to find the natural frequency of a Cantilever Beam. The beam is tapered in breadth, but has a uniform thickness. So basically the end goal is an equation for f as a function of the angle of the side cut.
Clamped at one end
L=constant
B=changes though the length of the beam and is dependent on the angle from the z axis (along the beam)
H=constant (thickness)
E constant,
So obviously the second moment of area will be a function of x or angle.
The end equation will be used in MATLAB to for a plot angle vs frequency
Any pointers, or a solution would be most helpful,
Thanks for your time
Just an incomplete idea -
Find an equivalent system of a massless beam with a point mass at the end. Then use the stiffness of the beam, and the point mass as a simple spring-mass system and get the fundamental frequency from \omega = \sqrt{\frac{k}{m}}
If I understood your description correctly, your "beam" is the same shape as a slice cut out of a circular disk with a hole in the middle.
Formulas for the vibration of disks are well known, though you might have to find the derivations and extend them yourself to the case with a hole in the middle. The math involves Bessel functions.
You would need to take Poisson's ratio = 0, so there would be no circumferential strain in the solution for the full disk, and cutting it into "slices" would not make any difference. The simplest beam theories don't depend on Poisson's ratio at all, so this should work out OK.
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
