Why Does Angular Diameter Distance Decrease After Redshift z=1.5?
  • Thread starter Thread starter semiserious
    Angular Diameter
The angular diameter distance decreases after a redshift of z = 1.5 because the universe was significantly smaller at that time. The angular diameter of an object is determined by its size when the light was emitted, not by the expansion of the universe, which does not alter angles. As light travels, it stretches, but the angular size distance reflects the distance of the object at the time the light was emitted, which is smaller than its current distance. For example, matter that emitted the Cosmic Microwave Background (CMB) light was only about 41 million light-years away when that light was emitted, despite being approximately 45 billion light-years away today. Understanding these concepts clarifies why angular diameter distance behaves this way at higher redshifts.
semiserious
Hi,
Can anyone explain (physically) why the angular diameter distance starts to decrease after a certain redshift (around z = 1.5)? Thanks
Space news on Phys.org
semiserious said:
Hi,
Simply put: our universe was much smaller back then.
semiserious said:
Hi,
Semi, you got your answer! Chalnoth put it concisely.
One thing you could concentrate on understanding is this: the angular diameter of something is the angular diameter it had when the light was emitted and started on its way to us.
Because pure expansion does not change angles. If you think diagrammatically, the lightrays are not spread apart or squinched together by expansion. They are just stretched out longer.
But the angular-size distance is just based on the angular diameter of some standard ruler (like a 100 thousand lightyear galaxy), and since the angle spread of the incoming light does not change
the angular size distance equals the distance of the object when the light was emitted.
And that is smaller than the presentday distance by a factor of z+1.
semiserious said:
Hi,
the angular size distance equals the instantaneous proper distance to the object measured on the day when the light was emitted.
So think about this example: the matter that emitted the CMB which we are now detecting is now about 45 billion LY from us. But the redshift of that ancient light is z = 1090. So the distances have increased by a factor of z+1 = 1091. Not to be too fussy, distances have increased by a factor of 1100.
So when the light was emitted, that matter was only about 41 million LY from our matter! When the ancient light was emitted, the matter was much much closer
Abstract The Event Horizon Telescope (EHT) has significantly advanced our ability to study black holes, achieving unprecedented spatial resolution and revealing horizon-scale structures. Notably, these observations feature a distinctive dark shadow—primarily arising from faint jet emissions—surrounded by a bright photon ring. Anticipated upgrades of the EHT promise substantial improvements in dynamic range, enabling deeper exploration of low-background regions, particularly the inner shadow...
https://en.wikipedia.org/wiki/Recombination_(cosmology) Was a matter density right after the decoupling low enough to consider the vacuum as the actual vacuum, and not the medium through which the light propagates with the speed lower than ##({\epsilon_0\mu_0})^{-1/2}##? I'm asking this in context of the calculation of the observable universe radius, where the time integral of the inverse of the scale factor is multiplied by the constant speed of light ##c##.
