Complex functions, (z+i)^5 + (z-i)^5
L-x
solve
(z+i)^5 + (z-i)^5 = 0
I have found the five possible values for z by expanding the original expression into powers of z and i. The imaginary terms cancel exactly, leaving a cubic equation in z which is easily solvable as one of its roots is z=0.
The answers quote the solutions as z = cot[pi(1 + 2n)/10], n = 0, 1, 2, 3, 4. The values I obtained are z=0, z^2=5+sqrt(20), z^2=5-sqrt(20).
My answers are roots of the equation, but the way that the solutions are written suggests that there is a (probably neater) method than the one I used which uses trigonometry. Can anyone see it?
so you did as follows, to get to a quadratic equation in z^2?
(z+i)^5 = z^5 + 5z^4i + 10z^3i^2 + 10z^2i^3 + 5zi^4 + i^5
(z-i)^5 = z^5 - 5z^4i + 10z^3i^2 - 10z^2i^3 + 5zi^4 - i^5
(z+i)^5 + (z-i)^5 = 2z^5 + 20z^3i^2 + 10zi^4
= 2z^5 - 20z^3 + 10z
= 2z(z^4 - 10z^2 + 5)
yes, exactly that.
another way to look at it could be
(z+i)^5 = -(z-i)^5
(z+i)^5 = (i-z)^5
but not too sure where to go from here...
might be worth writing cot[pi(1 + 2n)/10] in terms of complex numbers and substituting into the equation to see why it works
Hi L-x! :smile:
L-x said:
… the way that the solutions are written suggests that there is a (probably neater) method than the one I used which uses trigonometry. Can anyone see it?
Write the equation as ((z+i)/(z-i))5 = -1.
Then substitute z = cotθ. :wink:
thanks, that's quite a lot neater.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
