How Is Power Extracted from Wind Turbines?
Power extraction from wind turbines involves calculating the kinetic energy of the wind before and after it passes through the turbine blades. The initial wind conditions are given as a density of 1.2 kg/m³ and a speed of 8 m/s, while the conditions after passing the blades show a reduced speed of 3 m/s and a density of 1.8 kg/m³. The formula for power extraction is P = 1/2 * p * A * v³, where A is the surface area of the turbine blades. Additionally, there is a request for assistance in calculating the surface area of wind turbine blades, with inquiries about relevant formulas or software tools. Understanding these calculations is crucial for optimizing wind turbine efficiency.
Pseudopro
Air of density 1.2kgm-3, speed 8ms-1 is incident on blades of wind turbine. Radius of blades 1.5m. After passing blades, wind speed is reduced to 3.0ms-1 and density 1.8kgm-3. How much power is extracted from wind?
P=1/2 pAv3
P=1/2 x 1.2 x pi x 1.52x 83. But I don't know what to do with the information about the wind after passing blades.
I've solved it - thank you for your time :)
How to calculate surface area of wind turbine blade
i want to calculate surface area of wind turbine blade,
can anyone help me out,any formula or software for it?
