Why does the Rankine cycle require the condensation of water before reheating?
The Rankine cycle requires the condensation of water before reheating to ensure efficient phase change from steam to liquid, as liquid water is easier to pump back into the boiler than steam. This process minimizes the risk of cavitation in pumps, which can occur if any gaseous phase remains, potentially damaging the equipment. Although it may seem that feeding higher temperature water directly to the boiler could save energy, the additional power needed to pump steam outweighs the benefits. The condenser's role is crucial for maintaining operational efficiency and protecting the pumping system. Overall, complete condensation is essential for optimal performance in steam power plants.
fred2028
In a Rankine cycle such as a steam power plant, why does the liquid (water) have be condensed before being reheated first? Isn't the Q just extracted during the condensation stage, wasted into a nearby reservoir, and then re-added in the boiler? Could this water not be fed straight to the boiler, and because it is at a higher temperature than fully condensed water, would require less W to heat it?
When the working fluid (water, or steam more precisely) exits the turbine, it is still in a gaseous state. The function of the condenser is to perform the phase change of the steam back into liquid water. Liquid water takes less power to pump back into the boiler than steam does.
What SteamKing said seems like a good answer, I'd just like to add one thing: Pumps like to work in either a fully liquid or fully gaseous regime. This is why the condenser completely condenses the working fluid. If the working fluid were to have some gaseous component to it, you run the risk of cavitation occurring in your pump, which will kill the pump rather quickly.
Thanks, so in this case, the pumping would require more power than the amount of power the condenser and boiler would save?
Thanks for the reply!
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
