antekatavic
- 36
2 questions. 1. why vacuum is not used in hydro electric power plants and 2. why water under presure from big depths are not used for revolving turbines?
1. with vacuum you would need only small amount of water faling from a big altitude to revolve turbine. Turbine would revolve faster and longer because there is no air resistence and also there would be no noise and corrosion.
2. if you put turbine and everything you need to produce electric in a some kind of submarine and went to a big depth of a sea,lake or a ocean and then every now and then let the water under presure revolve turbine, or maybe it is possible to relocate that water under presure to a surface where it will revolve turbine. If you take a big hose that is wide at the bootom of the sea and narrow at the surface and with a combination of the same way you suck up your petrol from a tank of a car maybe it would work.
