Calculating Wave Properties: Frequency, Wavelength, and Speed
The discussion focuses on calculating the frequency, wavelength, and speed of a wave described by the equation y(x,t)=(5.2cm)cos(5.5x/m+72t/s). To find the frequency, it is noted that the angular frequency (w) relates to frequency (f) through the equation w = 2πf, allowing for direct calculation. The wave number (k) is connected to wavelength (λ) by the equation k = 2π/λ, enabling the determination of wavelength from the given values. The speed of the wave is confirmed to be 13 m/s, calculated using the relationship v = w/k. The discussion emphasizes correctly identifying and applying the relationships between wave properties for accurate calculations.
anotherperson
the displacement of a wave traveling in the negative x-direction is given by
where x is in metres, t is in seconds, calculate:
i)the frequency
ii) the wavelength
iii) the speed of this wave)
i have absolutely no idea how do calculate the first 2. i thought you could just read the frequency and wavelength of the equation but this doesn't match my solutions
i know part iii) will be speed=72/5.5= 13 m/s
Remember that the equation of a wave is y(x,t) = ymsin(kx +- wt). In this case its s(x,t) = smcos(kx +- wt). Your equation above takes the form of the latter. Frequency is related to w by the equation w = 2pi f where f is frequency - so just plug in the w from your equation and solve. Also, k is related to wavelength (I'll label wavelength as y) by the equation k = (2pi)/y. Here you also just need to plug in your values from the equation and solve. And yeah, you're right about the speed. v = w/k.
this is exactly what i had done but i had used k for w and w for k, that's for the help!
thanks**
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
