Seeking Thermal Insulator & Electrical Insulator for Peltier Device
A user is seeking a thermal and electrical insulator for a Peltier device, as current epoxy options are causing short circuits with the semiconductor array. Suggestions include creating a wax-coated 3D model to form a protective glove for the leads and allowing the epoxy to partially set before application. The discussion highlights the abundance of epoxy formulations available, emphasizing the need for careful selection to avoid conductive options. Resources such as manufacturer websites and direct communication with applications engineers are recommended for finding suitable products. The conversation underscores the importance of consulting experts in epoxy materials for effective solutions.
Kvm90
Hey all,
I'm using a peltier device for a cooling system I'm working on. The metal leads connecting the peltier to a power source keep falling off. I am looking to coat them with epoxy that must be a thermal insulator. It also MUST be an electrical insulator.
The problem I've had is that the epoxys I'm using run into the p and n doped semiconductor array and short my peltier. A viscous epoxy is much needed so that no running of the epoxy into the p and n semiconductors occurs.
Any suggestions?
Thanks!
Hmm, you could seal it prior to the epoxy, but the sealant may cause trouble also.
Make a dummy 3D model of your device including the leads. Cover it in wax. Coat it with epoxy. When the expoxy dries, pull the expoxy off. It will come off because of the wax. Then this hardened "glove" should slip on over the leads of your device.
If the problem occurs when applying the eopxy, you could let your existing epoxy partially set before applying it to the Peltier module.
There are about a million different kinds of epoxy formulations. They are as common place in the electronics industry as copper. For example, the black plastic that encapsulates ICs is an epoxy resin variant. I am surprised that the ones you've tried are conductive, that is an unusual configuration for these resins. Anyway, I can pretty much guarantee that there is one that will work and be easy to use. The problem is selecting one of the many options.
Frankly, I'm kind of surprised every time I read a question like this in these forums, when the answer clearly lies with people who know enough about epoxies to name at least 10 different flavors. That's not us.
1) Try google.com, there's a lot more useful information there about specific products and common engineering solutions. Look at the manufacturers of the products you are curious about and read the technical information they have posted.
2) Call or email (calling is better IMO) the applications engineers at one of the many epoxy manufacturers. Here's one place you can start with:
https://www.masterbond.com/techtips/optimizing-electrical-electronic-insulation-properties-epoxies
3) For questions about TEC installation and use, you can call TEC manufacturers, like Marlow.
https://blog.marlow.com/topic/technical-library
Notice on both of the pages I linked to they have prominently displayed their contact phone number. It's their job to help you choose the right product. They want you to call them.
Likes phinds
Your epoxy is electrically conductive? That's weird. Try Torr-Seal, expensive but viscous and non-conductive and excellent in vacuum.
You also might try that stuff advertised on late night that is a glue material that is cured with a UV LED. Put in on upside down, cure it and then right side up.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
