How do I write this interesting piecewise function?
The discussion focuses on creating a piecewise function for a spring-mass system where a 32-pound object is attached to a spring with a spring constant of 1. The object is initially pulled down 5 feet and released with a velocity of -1 ft/sec, experiencing a periodic forcing function that changes direction after traveling 10 feet. Participants suggest using unit step functions and Laplace transforms to define the piecewise function accurately. The proposed piecewise function includes segments for different intervals, specifically f(t) = t for -5 < t < 5 and f(t) = 10 - t for 5 < t < 15, with periodic extensions. The conversation emphasizes the importance of correctly defining the function within specified intervals to solve the governing differential equation.
JosephK
[URL]http://www2.seminolestate.edu/lvosbury/images/VibSpringAnNS.gif[/URL]
Find the governing differential equation and position functions for a 32 pound object attached to the end of a spring with a spring constant of 1 and a forcing function that yields a constant velocity in the direction of motion. This velocity changes sign periodically. The forcing function is piecewise. The object is pulled down until the spring is stretched to 5 feet below its equilibrium position and then the object is released with an initial velocity of -1 ft/sec and the forcing function produces a constant velocity of -1 ft/sec. After the object has traveled 10 feet it is impeded and reverses direction with an initial velocity at that point of 1 ft/sec. and the forcing function changes to produce a constant velocity of 1 ft/sec. This behavior continues indefinitely.
I am interested in only finding the piecewise function.
I drew the graph.
[URL]http://assets.openstudy.com/updates/attachments/4dfd29cf0b8bbe4f12e6e1ca-joseph20111-1308436975669-piecewise.bmp[/URL]
I think I can use a calculator function such as frac(x) or int(x).
I wrote a piecewise (unfinished) function that I believe can be simplified.
[URL]http://assets.openstudy.com/updates/attachments/4dfd29cf0b8bbe4f12e6e1ca-joseph20111-1308447921585-pie.bmp[/URL]
-t represents line with negative 1 slope. t represents line with positive 1 slope.
I wrote (1)^n * t for alternating t.
To write inequalities, 5 + 10n.
Your forcing functio is periodic with period 20. The simplest thing to do would be to solve it as two separate problems for -5< t< 5 and then for 5< t< 15.
Your piecewise description of your forcing function is not correct. For the period from -5 to 15 your formula would be:
f(x) = x, -5<x<5
f(x) = 10 - x, 5 < x < 15
You can write this portion of f(x) using the unit step function u(x):
f(x) = x + (10-2x)u(x-5) for -5 < x < 15
and call F(x) the periodic extension of f(x) with period 20. Then you could solve the DE using LaPlace transforms, making use of the expression for the LT of a periodic function.
f(t) = t, -5<t<5
f(t) = 10 - t, 5 < t < 15
I think I can find the Laplace transform of this periodic function.
JosephK said:
f(t) = t, -5<t<5
Since your piecewise function is actually not defined for t < 0, you should use a formula on (0,20) to take the LaPlace transform. I think it is:
f(t) = t -10u(t-5) - 10u(t-15) on (0,20)
but you can check to be sure.
I drew the graph.
One way of representing this that comes to mind is to use a x arcsin(sin(bx)) for constants a and b. From your drawing let a = A and b = pi/10 and hopefully that should give you what you need.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
