How Do You Calculate the Normality of KMnO4 in This Stoichiometry Problem?
The discussion focuses on calculating the normality of a KMnO4 solution used to oxidize H2O2 in a stoichiometry problem. Participants clarify that the reaction equation must accurately reflect the reduction of permanganate to Mn2+ in acidic conditions. The correct approach involves determining the weight of H2O2 in the solution as x/100 grams and calculating the number of equivalents based on its equivalent weight. The final normality of the KMnO4 solution is established as 0.58 N through the derived equations. The conversation highlights the importance of understanding stoichiometric principles and balancing chemical equations correctly.
Quantum Mind
Stoichiometry problem
1 g of H2O2 solution containing x % of H2O2 by weight required x ml of KMnO4 for complete oxidation in acid medium. What is the normality of KMnO4 solution?
H2O2 + KMnO4 => 2KOH + 2MnO2 + 2O2
1 g of H2O2 solution contains x% of H2O2.
Molar mass of H2O2 = 34 g, which means in 100 g of solution, 34g of H2O2 are present. In 1 g of solution, 0.34 grams of H2O2 are present. This reacts with 34 ml of KMnO4.
I know that 17 g of H2O2 will react with 158.03 g of KMnO4, based on law of fixed proportions. The problem here is only the volume has been given and not the weight. The formula for Normality i.e. 1 mol / 1 L whereby 34 ml or 0.034 L is substituted in the denominator is not correct.
I know I am doing something wrong, but can't figure out what it is. Any help is appreciated.
The answer is 0.58 N.
I am struggling with stoichiometry and I hope that I will be allowed to post thorny (from my point of view) problems in this thread.
First of all - your reaction equation is wrong. Permanganate in acidic solution gets reduced to Mn2+.
No, 1g of the solution contains 0.x g of H2O2
Please start a new thread for each problem.
Can you give the equation?
I am beginning to understand. Guess my whole understanding was off. Since it says that the solution contains x % of hydrogen peroxide, I can't assume it as 34% by weight. Is this correct?
The solution is to take the weight of hydrogen peroxide as x/100 in 1 gram. Since the equivalent weight of H2O2 is 17, the number of equivalence in this solution would be x/1700.
How do I proceed beyond this?
Come on, you can. And if you don't know how to balance the equation - its time to learn it. Products are Mn2+, H2O and oxygen. Potassium is just a spectator, if you will balance net ionic equation it will not interfere. And don't forget solution is highly acidic, you will need a lot of acid on the left.
2xYes.
Express number of equivalents in x mL of the titrant solution as a function of x and concentration. You will have two equations in two unknowns.
Equivalents in KMnO4 will be Nx/1000
x/1700 = Nx/1000
N = 10/17 or 0.58 N.
Got it, thanks.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
