QUESTION: N.m Torque Calculation for Rotating Square Plate
  • Thread starter Thread starter gauravkukreja
    Torque
A square plate with a side of 5 cm is rotating around one of its edges, and the angular acceleration is 0.2 rad/s². To calculate the torque, the mass of the plate is needed, which is assumed to be 80g. The formula for rotational inertia is I = 1/2 MR². The calculated torque is 2.0 * 10^(-5) N·m. Participants are encouraged to share their complete problem and work for verification of their solutions.
gauravkukreja
CHECK OUT THIS PROBLEM
A SQUARE PLATE OF SIDE 5 cm IS ROTATING AROUND ONE OF ITS EDGES. IF THE ANGULAR ACCELARATION OF THE BODY IS 0.2 rad/s/s, FIND THE TORQUE.
ANSWER:2.0 * 10^(-5)
(TWO INTO 10 RAISED TO -5)
You need the MASS of the plate to calculate its rotational inertia I=1/2MR^2.
The mass should be given as 80g, right?
If you would like someone to check your SOLUTION to the problem, do two things:
(1) Post the complete problem
(2) Show your work
